Trouble keeping car running after warm up..
Old Jan 16, 2007 | 08:05 PM
97Purp's Avatar
97Purp
Default Trouble keeping car running after warm up..
Like the topic says, I have a 1997 DOHC coupe model, runs good when started, runs good for a bit after being at running temp.... But then it will just die, its happend to me a few times, ive been told it was the coil pack? so i changed it out with another one (was from a used car) and it still died out after runing for about 45 min or so... Any ideas? its my winter car and i need it to get to work etc.. Thanks for your impute guys!
Old Jan 16, 2007 | 08:35 PM
spudsterier's Avatar
spudsterier
Default RE: Trouble keeping car running after warm up..
sounds like an 02 sensor problem.....
when the 02 sensor goes bad your car will run fine until it gets warm...then it will start acting funny
is the check engine light on?????
Old Jan 16, 2007 | 08:51 PM
97Purp's Avatar
97Purp
No, no check engine light is on, but thanks for the idea, does sounds like a good probability.. How many are there? Just one i hope? hehe
Old Jan 17, 2007 | 12:07 AM
spudsterier
you have (2) 02 sensors....an upstream and a downstream.....the only one that might cause this problem though would be the upstream.....the downstream just keeps an eye on the cat. convertor to make sure its working properly
Old Jan 17, 2007 | 07:01 AM
97Purp's Avatar
97Purp
Cool shouldnt be hard to do on a 19 degree day hehe, is there any other possibilities? A couple riends of mine were mentioning the ignition module? Where would this be ? Thanks for your input!
Old Jan 17, 2007 | 01:33 PM
spudsterier
ignition module...hmm
maybe the coil pack????
there are alot of things that it could be.....put up a post in the 1st gen section and ask the same question....you will get more responses there
