Where to get the thicker layer head gasket from?
Can I get it at autozone?
Can I just use the 00+ style from autozone?
Can I just use the stock style, with shaved down head bolts, just to retain the stock compression ratio?
Do I need any other gaskets?
Thanks, Andrew
Thanks, Andrew
Fel-Pro makes an MLS gasket for the Neon that can be picked up or special ordered at many local or on-line auto part stores. Their MLS brochure and application guide are on the Federal Mongul site at:
http://www.federal-mogul.com/vgn/ima...20Brochure.pdf
http://www.federal-mogul.com/vgn/ima...28AppGuide.pdf.
I think Dodge/Chrysler probably uses a different source for their MLS replacement gasket, so the dealer is another option.
