Neon
Old Jan 22, 2007 | 06:41 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default Neon
Hey please answer!! I have not had too much luck with my questions on here before, but here it goes. Like I said in my previous posts I have narrowed my problem down to the wiring harness. My question is will a engine harness from a 01 neon work in a 97? If there are only a couple of minor changes I can deal with that but the scrap yard I have my credit at only has one of an 01. THANKS!!
Old Jan 22, 2007 | 08:58 PM
fullbuilt's Avatar
fullbuilt
Default RE: Neon
the plug in to the pcm is different for the 03 but im not sure about the 01. give it a shot if it dosent work get your credit
Old Jan 22, 2007 | 10:37 PM
neoncrazy101's Avatar
neoncrazy101
Default RE: Neon
the sensors might be a little different as well.
Old Jan 23, 2007 | 10:03 PM
djmagic's Avatar
djmagic
Default RE: Neon
I don't think so because the body styles are completely differentand I think the 01 engine is bigger because if I remeber right the 98 is a 1.6 while the 01 is a 2.0.
Old Jan 24, 2007 | 12:59 AM
das2123's Avatar
das2123
Default RE: Neon
ORIGINAL: djmagic
All neon engines are 2.0L, with the exception of the SRT-4.
No, the wiring harness will not just plug in. The PCM is different.
Old Jan 24, 2007 | 08:49 PM
djmagic's Avatar
djmagic
Default RE: Neon
I thought the older ones were a 1.6. Shows you how much I admire the old ones... no offense
Old Jan 25, 2007 | 02:06 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: Neon
Nope, they're all 2.0L's. The only big differences are that there are SOHC versions and DOHC version and the newer SOHC's had versions withmore power than the previous ones.
Old Jan 25, 2007 | 11:23 AM
das2123's Avatar
das2123
Default RE: Neon
ORIGINAL: 71RoadRunner
True to a point. The regular SOHC's are still rated at 132HP, but the Magnum SOHC is rated at 150HP.
Old Jan 26, 2007 | 12:58 AM
71RoadRunner
Default RE: Neon
Yup, that's why I said,"the newer SOHC's had versions with more power than the previous ones."
Old Jan 26, 2007 | 11:46 AM
das2123's Avatar
das2123
Default RE: Neon
Oops, I missed the versions part[&o]
