Wiring diagram
Old Aug 13, 2004 | 01:10 AM
LowSlowNeon's Avatar
LowSlowNeon
Default Wiring diagram
Can someone point me to someplace that has a wiring diagram for a 04 Neon. What I need it for is wiring up my foglights to run whenever I want. I have looked around for awhile and didn't find one, so I thought I would ask and see if anyone could help me out.
Old Aug 13, 2004 | 03:04 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Default RE: Wiring diagram
Ask and ye shall seek.
I've also been building custom harnesses for fog lights for years, in case you wanted to run higher wattage bulbs I can fabricate you a harness that is oil, fuel, coolant, salt, corrosive, water resistant and is rated for 1200+ watts and 600+ volts. The harnesses include everything for installation (electrically) which include, switch and fuses, all connectors. All that I ask is for you to send your fog lights to me so I can correctly built the harness specifically for your lights. Cost is dependent on time and parts. I can usually put a harness together in 4 hours and the cost is usually about $100. They also come with instructions on how to convert the harness over to a different set of lights in case you change the lights completely over to a different set.
Old Aug 13, 2004 | 03:10 AM
04dodgeneon's Avatar
04dodgeneon
I was hoping someone would post up a complete wiring diagram for an 04 Neon. I couldn't find one.
Old Aug 13, 2004 | 08:23 AM
sauceboy's Avatar
sauceboy
they were talking about doing that over on the srt-4 forum. i think they might have what you need there.
Old Aug 13, 2004 | 06:34 PM
Cr@zy Squ33
Unfortunately if it is an aftermarket set of lights I doubt there is any way of hooking them up to the wiring harness that comes in the car already.
At any rate. Good luck to ya.
Old Aug 13, 2004 | 07:40 PM
LowSlowNeon
Sauceboy, I already saw that post, but thanks anyways. If I was going to do the actual rewiring I would probably follow that website, but I'm not. A friend of mine is going to help me and he wanted a wiring diagram because it doesn't need to be anything fancy like that website. It just needs to "work".
Old Aug 13, 2004 | 07:52 PM
Cr@zy Squ33
What are you trying to do? Because if it's what I'm thinking you aren't going to be able to do it that way.
