transmission problem
Old Aug 20, 2004 | 09:37 PM
neon99phanatic's Avatar
neon99phanatic
Default transmission problem
hello,
i just bought a '99 dodge neon about a week ago. it seemed fine when i first test-drove it, but now the transmission is starting to jerk when the gear changes from 1st to 2nd.
i checked the fluid, but nothing's wrong with it. [:'(]
can anyone tell me what the problem is? also, any advise on how to fix the problem? thanks.
oh, and it's a sohc engine with 94,000 miles. i was told that it's mostly highway miles.
Old Aug 20, 2004 | 09:38 PM
sushi423's Avatar
sushi423
Default RE: transmission problem
stick or auto?
Old Aug 20, 2004 | 10:13 PM
Spyder1427's Avatar
Spyder1427
lucas transmission fix works wonders.
Old Aug 20, 2004 | 10:29 PM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Yes, Manual or Auto?
And you could try servicing it. Just because the fluid level looks good doesn't mean it is good.
Old Aug 21, 2004 | 12:13 AM
casper's Avatar
casper
Try doing a flush, filter change. If you do it yourself make sure you use the correct fluid. Do not use that lucas crap it may work but it just masks the problem and just for the information a dealer will void any warenty you have if you do.
Old Aug 21, 2004 | 03:36 AM
neon99phanatic
yes, it's auto. and the biggest jerking happens when i move the shift into the Drive. (right after i start up the car)
Old Aug 21, 2004 | 01:30 PM
Cr@zy Squ33
I'd service the transmission.
