Dodge Nitro The Dodge Nitro is a sporty mid size SUV that bound to turn heads where ever it roams. The Dodge Nitro is one fun ride!
seatbelt alarm
Old Apr 9, 2008 | 04:28 PM
balou's Avatar
balou
Default seatbelt alarm
is there a way i can take that out ..very annoying
this is for when the seatbelt is not in use
Old Apr 13, 2008 | 04:24 PM
Jas_Oz's Avatar
Jas_Oz
Default RE: seatbelt alarm
You could try this;
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the ON
or START position. DaimlerChrysler does not recommend
deactivating Beltalert.
1. Turn the ignition switch to the LOCK position and
buckle the driver’s seat belt.
2. Turn the ignition switch to the ON position and wait
for the Seat Belt Warning Light to turn off.
3. Within 60 seconds of turning the ignition switch to the
ON position, unbuckle and then re-buckle the driver’s
seat belt at least three times within 10 seconds, ending
with the seat belt buckled.
NOTE: Watch for the Seat Belt Warning Light to turn on
while unbuckling and off while re-buckling the seat belt.
It may be necessary to retract the seat belt partially each
time when unbuckling.
4. Turn the ignition switch to the LOCK position. A
single chime will sound to signify that you have successfully
completed the programming.
