Nitro 2007 crd se engine cuts out
Had a problem when first bought the car 2010 a a certain temp the end stalled. Took to Dodge garage did diagnostic and found a cable to the injectors had worm down was shorting and cause the fault ECU end result engine stalled. They changes the cable all was ok for 6 months. Then took the car to north africa where i work drove 2000 miles no problem yesterday same problem engined stalled nearly has an accident. took to garage they fixed one of the four injectors and said I needed to replace the managment system for the injectors(automatic) this is cause error. I dont know anyone else had similar problem with Dodge nitro 2007 crd se manual diesel
Welcome to the forum. I don't think that the diesel is an option here in the states. Maybe someone else here can help. It is possible that the bad injector had shorted out the system. Good luck.
