Dodge Nitro The Dodge Nitro is a sporty mid size SUV that bound to turn heads where ever it roams. The Dodge Nitro is one fun ride!
2008 Nitro back power outlet not working
Old May 13, 2013 | 01:43 PM
ebdzgns's Avatar
ebdzgns
Default 2008 Nitro back power outlet not working
I have power outlet on the back of my center console facing the back seats. There is no power to it. My cigarette lighter outlet works up front. Is there a fuse that is for this back outlet for me to check before I take it to the dealer so they can dig around and see what it is........
Old May 14, 2013 | 09:57 AM
DodgeCACares's Avatar
DodgeCACares
Ebdzgns,
Is the power inverter turned on? Press the switch located in the center stack lower switch bank to turn the power on to the outlet. When the inverter switch is pressed, there will be a delay, approx. 1 sec before the inverter status indicator turns on. The status indicator of the AC power inverter indicates whether the inverter is producing AC power.
Please note that due to overload protection, the inverter will shut down if the power rating is exceeded (Max 150 Watt).
The Power Inverter is #4 on the diagram, I hope this helps. PM me if you have any questions.
