Dodge Nitro The Dodge Nitro is a sporty mid size SUV that bound to turn heads where ever it roams. The Dodge Nitro is one fun ride!
2007 r/t oil pan
Old Apr 24, 2021 | 08:03 AM
superdak05's Avatar
superdak05
Default 2007 r/t oil pan
looking for a 2007 4.0 oil pan, drain plug is leaking pretty bad even after new oem plug and gasket, every where I looked the part is either discontinued or the dealer wants and arm and a leg. forget going used, anyone ever weld the original hole and drill and tap a new plug?
Old Apr 26, 2021 | 11:30 AM
gmyhilo's Avatar
gmyhilo
Default will this work?
See lisle tool # 58850
you can test if oil pan thread is hardened by trying to scratch with small file, if file cuts it's not hardened.
Old May 2, 2021 | 10:34 AM
superdak05's Avatar
superdak05
i will look into this, appreciate the feed back thank you
Old May 2, 2021 | 12:47 PM
gmyhilo's Avatar
gmyhilo
Please let me know what you do to solve the problem.
