Cracked Window
Old Apr 1, 2007 | 10:46 PM
DIRTYRAMIN's Avatar
DIRTYRAMIN
Default RE: Cracked Window
My 06 drivers window cracked while parked at work this winter. It made a flower pattern up from bottom. I took it to local dealer and they replaced it...no charge. Mane reason was because it started from inside of door and went up from there.
Old Apr 1, 2007 | 10:58 PM
Drew's Avatar
Drew
DTR = Diesel Truuck Resourse.
next time you have your keys locked in your car/truck, just call someone on your cell phone to get your other key and call back when they have it in hand. . .tell them to put the key fob next to the microphone and push the unlock button while you hold your cell phone near the drivers door. . .it should unlock.
Old Apr 1, 2007 | 11:00 PM
FroneDaddy's Avatar
FroneDaddy
ORIGINAL: UpBranchLiner
DTR?
I think he means TDR (Turbo Diesel Register)
Old Apr 1, 2007 | 11:13 PM
handymanherb's Avatar
handymanherb
ORIGINAL: Drew
That will not work, it is a myth, phones can't transmit the signals needed to unlock the doors
Old Apr 1, 2007 | 11:20 PM
squirtbottle09's Avatar
squirtbottle09
yep
Old Apr 2, 2007 | 12:05 AM
UpBranchLiner's Avatar
UpBranchLiner
I heard that was a myth too, anyone tried it?
Old Apr 2, 2007 | 12:24 AM
Drew's Avatar
Drew
theres a video on youtube where they do it to a new jetta
they also use a tennis ball to unlock the door as well.
Old Apr 2, 2007 | 12:55 AM
aka_chewy's Avatar
aka_chewy
I tested that cell phone myth on 4 different vehicles and none of them worked. My thought is that cell phones transmitwith signals different from what the key fobs do; so how can the correct signal enter the phone, cross the airways riding on a different signal, the exit the phone keeping the correct signal information and transmit to the vehicle. It doesn't make sense to me.
Now, I have no knowledge of how things transmit and such so I make no claims to as if this is right. It's just what I think is happening.
Old Apr 2, 2007 | 01:43 AM
CowboyBob's Avatar
CowboyBob
You will have better luck unlocking your door with a cell phone if you just threw the phone at the window.
Old Apr 2, 2007 | 05:13 AM
DiEseLjunKy's Avatar
DiEseLjunKy
ORIGINAL: FroneDaddy
DTR?
diesel truck resource
