Remote starter for diesel truck
Old Jan 23, 2008 | 11:56 AM
  #31
GOD RAM IT's Avatar
GOD RAM IT
Default RE: Remote starter for diesel truck
well I did some reading and made some phone calls.
I currently have remote start and get 2 codes everytime I use it. wastegate code and a fan clutch code.
I called all of the car audio type places around and most of them wont install remote starts on a diesel. and the ones that do dont recomend it.
I read the same on the web.
So I had my dealer take it out and put it in the inside of my truck.
The tecjh said there was some wires that were unhooked and poor connections. He said that was probably the cause of the codes. He then said he hasnt seen a remote start on a dodge diesel work correctly and it was a good idea to remove it.
the system was a valet remote start system. the dealer had a loscal shop check it out and the starter is fine it was just installed wrong. so I will see if I cant sell it some how.
Old Jan 23, 2008 | 08:11 PM
  #32
agargano98's Avatar
agargano98
mine is compustar 2W900FMR 2nd. i have had it 5 months now with no problems so far down to 0 degrees starts every time
Old Jan 23, 2008 | 08:32 PM
  #33
speakle's Avatar
speakle
ORIGINAL: GOD RAM IT
If that is the case than everyone in your area is an idiot. I have installed3 remote starts in my life, 2 in my old silveradoand one in my old '06 ram. It worked fine.
Old Jan 23, 2008 | 09:09 PM
  #34
JimmyDiablo's Avatar
JimmyDiablo
Can someone answer me if the vipers would have a delay restart. I have a 771 on my mini van, and I could have sworn one time I started it, let it run 12 minutes I believe it ran before turning off. then it started again. I do nto know how long it took to restart but can that be adjusted? I am looking for something to start every two hours and run 10-15 minutes.
Old Jan 23, 2008 | 09:13 PM
  #35
agargano98's Avatar
agargano98
i can program mine to do that
Old Jan 23, 2008 | 09:21 PM
  #36
JimmyDiablo
ORIGINAL: agargano98
What model do you have?
Old Jan 23, 2008 | 10:38 PM
  #37
agargano98's Avatar
agargano98
Old Jan 23, 2008 | 11:03 PM
  #38
JimmyDiablo
Thanks.
Old Jan 23, 2008 | 11:31 PM
  #39
speakle's Avatar
speakle
Here is a link to the owners manual of your RS unit http://www.directeddealers.com/manua...567V_07-05.pdf. I looked through it and dont see that you can set it to run on its own (my code alarm used to let me set it to start at a certain temp, I would think viper would have something similar), only the duration of the run time.
Old Jan 23, 2008 | 11:59 PM
  #40
JimmyDiablo
ORIGINAL: speakle
Thanks, now if only it was on the truck and not the van[sm=confused06.gif]... Nah. easier to just buy a new unit then to hack into wires.
