Electric Brakes
Old Apr 5, 2007 | 07:32 PM
trix77's Avatar
trix77
Default Electric Brakes
So I go to the nearest parts stoer and buy the electric brake module and the wiring kit (which has plugs on both sides) and can not find where it plugs in. I had others look also and do not see it. Any help would be helpfull....
Old Apr 5, 2007 | 08:02 PM
DieselDemon's Avatar
DieselDemon
Default RE: Electric Brakes
ORIGINAL: trix77
Hold on while Carnac ascertains the year and model of your truck.
[IMG]local://upfiles/12792/4EE789DCEE7B4421B216608481A7CB89.jpg[/IMG]
Old Apr 5, 2007 | 10:29 PM
tkk2500's Avatar
tkk2500
On mine the connector was taped on top of the wiring block that is between the steering column and the emergency brake. There was a clip to release the wiring block.
Old Apr 5, 2007 | 10:56 PM
NickBeek's Avatar
NickBeek
Mine was on the fire wall behind the parking brake.
Old Apr 5, 2007 | 11:50 PM
trix77's Avatar
trix77
I guess what I forgot to mention was the year. The parts store guy came out because he had a 06' and knew where it was but we are thinking the 99 is diffrent. But anyway is the 99 in the same spot?
Old Apr 5, 2007 | 11:55 PM
Watermelon's Avatar
Watermelon
It should be in the general area, I think it is a blue connector. I had a 2000 CTD and it was beside the emergency brake on the fire wall.
Old Apr 6, 2007 | 12:35 AM
lesimon's Avatar
lesimon
I found mine way up under the dash took a while to find, the dealer said that someone must have stuffed it up there because they are not normally that high up.
Old Apr 6, 2007 | 12:41 AM
trix77's Avatar
trix77
Thanks everyone. I will look again in the morning.
Old Apr 7, 2007 | 04:38 PM
Parts/Service's Avatar
Parts/Service
Vehicles equipped with the trailer tow package also include an electric trailer brake wiring provision that terminates at a connector located on top of the large body harness connection under the instrument panel to the left of the brake pedal, as well as an electric trailer brake pigtail harness and an instruction card (1) that are stored in the glove box (2) when the vehicle is shipped from the factory.
Old May 18, 2007 | 07:50 PM
unclepudge's Avatar
unclepudge
Sorry to cut in I just bought the factory wire harness for my 2000 dakota,I am trying to hook up the trailer brake I found the connector near the brake pedal, hooked it to the brake controller and followed wires out cab to back of drivers front tire and the blue wire and two others stop at that connection,instructions tell me no splicing and to run blue wire through firewall to ? and doesn't explain anymore,question is where the wire dead ends at rear of tire can I hook blue wire there instead of through firewall? thanks again.
