Stacks on a mega cab?
Old Apr 10, 2007 | 07:53 PM
  #21
Mayfair's Avatar
Mayfair
Default RE: Stacks on a mega cab?
WOW .... that WILL look awesome !!!
How are they gonna get it around the trans and driveshaft?
Old Apr 10, 2007 | 07:57 PM
  #22
VegasVinny's Avatar
VegasVinny
I have no clue how thay are gonna do it. But they say they can, we will see. I still need to figure out protect the stacks from rubbing the whole in the bed and keep it from rattling.
Old Apr 10, 2007 | 08:03 PM
  #23
Drew's Avatar
Drew
miter cuts, thats what they are called.
anyhoo, usualy there is a brace that goes from the stacks to the bed and that secures the top end, then on the other end where the DPF is there should be a hanger.
if you hit this URL http://www.turbodieselregister.com/f...043&page=2and look at the second pic you will see the brace I'm talking about right below where the chrome part of the stacks start.
between these braces and the hanger you shouldnt have to worry about the bed. the hole cut in the bed may be around 1/4" clearance.
Old Apr 10, 2007 | 08:04 PM
  #24
RetroCow's Avatar
RetroCow
Before you have it rhino lined, get some Hi-temp spray in foam insulation (the hard kind not the squishy kind), fill the gaps and let it cure, trim with a knife and rhino line it
Old Apr 10, 2007 | 08:12 PM
  #25
VegasVinny's Avatar
VegasVinny
ORIGINAL: RetroCow
But the stacks need to be removable in case I have to replace tham at any time.
