dual exhaust
Old Apr 15, 2007 | 06:30 AM
06bighornspoolin's Avatar
06bighornspoolin
Default dual exhaust
any suggestions for a dual exhaust that isnt too loud in the cab for my son?
Old Apr 15, 2007 | 04:41 PM
Mayfair's Avatar
Mayfair
Default RE: dual exhaust
I've seen duals on diesels, but I'm still not sure how it's done ( where the crossover takes place )
Props to you though for hooking your boy up with duals !!! I'm sure he could care less how loud it is.
Old Apr 15, 2007 | 05:01 PM
cmnspwr's Avatar
cmnspwr
I'd get him the Silverlie Duals. My single is very quiet in the cab, almost like stock. Not too loud outside.
Old Apr 15, 2007 | 05:16 PM
cumminalong's Avatar
cumminalong
ORIGINAL: 06bighornspoolin
If all you want is duals and want to keep it quiet, all you need to do is get ay-pipe section added after the muffler and run it out both sides.
Any muffler shop that can do 4" tubing can do this.
Or you could buy a cat back system with either a muffler with single in / dual out or y-pipe after the muffler, but most of them will increase the noise.
There is no way to run TRUE duals on an inline diesel....unless you run a custom built exhaust manifold, dual turbos, dual mufflers, etc. Even on V8 diesels it would take 2 turbos and a lot of custom fab. Almost any diesel that you see with duals just has y or t-pipe section that splits the gases.
Y-pipe after the muffler would be with this part here.
[IMG]local://upfiles/39492/47166AB26ECE44C6BE8690956E1ED236.jpg[/IMG]
Or a cat or turbo back system like this here.
[IMG]local://upfiles/39492/648EE1AF6CCA4C77B07946A7098F8442.jpg[/IMG]
You can see how even on a complete system, most of them just use a y-pipe after the muffler.
Cheap, easy and quiet would be y-pipe after the stock muffler.
Old Apr 15, 2007 | 05:41 PM
Mayfair's Avatar
Mayfair
Wow thanks !!
I always wondered how it was done. That's pretty cool how they turn the Y pipe and the tails cross over one another.
Old Apr 15, 2007 | 05:59 PM
cumminalong
That's just how they do it on that particular system. It's a Bully Dog Rapid Flow.
Not all of them are stacked like that.
