front brakes - rant
Old Apr 19, 2007 | 04:23 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default front brakes - rant
anyone attemtped to do their own front brakes on a ctd truck yet?
93 ctd require the hub assembly to be pressed on and off of the rotor. you can buy a gasser hub/ rotor assy, but the hub is 1.5" I.D. and the diesel hub is 2.5" I.D.!!!!
so lets see, thats: 16 new wheel studs, 2 new rotors, and a machine shop to seperate the old and press on the new.......why so dang difficult?????
Dodge wants about $400 per hub/ rotor assy [sm=WTFsgign.gif]
ok Im done ranting.......
Old Apr 19, 2007 | 04:34 PM
Mayfair's Avatar
Mayfair
Default RE: front brakes - rant
YEP ... unfortunately I've had to do it twice now. I feel your pain brotha.
I've had brakes with 12K on them crack and destroy a set of new rotors even though I only went about 5 more miles to the shop. To have the rotors cut, you still hafta go through the same steps, so you might as well just replace them. Sucks !!!
Now I replace my front brakes every 10K needed or not. I just replaced both calipers and front brake lines as well. My truck stops better now than it ever did since I've owned it.
Old Apr 19, 2007 | 04:46 PM
Kev_n_AZ's Avatar
Kev_n_AZ
cant wait to dig into my faulty rears. one cyl already blew, line wouldnt come off so I had to temporaily crimp it closed. the other cyl looks like it has let go perty recently by the looks of the rear wheel.
ARG!!!! [:@]
I knew it needed work when I bought the truck last October.....
Old Apr 19, 2007 | 05:22 PM
Mayfair's Avatar
Mayfair
Well, look at it this way. Once you do the job, you'll KNOW when it was done and that it was done right.
