cruise control problems!
Old Apr 22, 2007 | 11:02 AM
Brian in PA's Avatar
Brian in PA
Default cruise control problems!
Hi guys! I'm having trouble w/ my cruise on my '01 CTD. It engages then it slowly keeps decelerating. Any Ideas?? Thanks in advance. -Brian
Old Apr 22, 2007 | 04:30 PM
DieselDemon's Avatar
DieselDemon
Default RE: cruise control problems!
My first guess would be the vacuum is bleeding off somewhere. You should have 2 in-line check valves. You can download the 2001 manual in PDF format, somewhere on this site.
Good luck with your ride.
Old Apr 22, 2007 | 06:04 PM
rbmason's Avatar
rbmason
I have problems with mine too, except instead of actually engaging, the light comes on but nothing sticks. Not a big deal really, but it sucks to drive long distances without it. No clue how to fix it either.
Old Apr 22, 2007 | 09:37 PM
FroneDaddy's Avatar
FroneDaddy
ORIGINAL: DieselDemon
Alot of time on the 2nd gen trucks the vacuum lines were right underneath the battery trays and if your battery would leak the acid would rot through the lines and cause a leak. I would check there as well.
Old Apr 25, 2007 | 12:58 AM
Brian in PA
Ok thanks I'll check the vacuum lines. Any ideas where to download the manual? Thanks!! Brian
Old Apr 25, 2007 | 01:03 AM
Ben D.'s Avatar
Ben D.
Where you located in pennsylvania man. I'm from lancaster county if you hppen to know that area of the state.
Old Apr 25, 2007 | 11:52 PM
Brian in PA
I'm from SW PA about 1/2 hour SW of Pittsburgh.
Old Apr 26, 2007 | 12:05 AM
DieselDemon
ORIGINAL: Brian in PA
I went to locomotive school in Conway, PA. We stayed at the Sewickly (sp). We drove around Moon, Coraopolis, Alliquippa, etc. I thought it was a nice area around Pitt. All they told us was stay away from the "Hill", or Hill district. Said it was a bad, bad area.
Adios.
Old Apr 26, 2007 | 01:08 AM
Ben D.'s Avatar
Ben D.
I know the general area ur talking about brian. I might be out that way a lot next year. I got accepted to University of Pittsburg but I've got a lotta other colleges that i can go to also . So we'll see.
Old Apr 26, 2007 | 03:16 PM
FroneDaddy's Avatar
FroneDaddy
Harrisburg here, 45 min from lancaster
