truck lacking power
Old 04-30-2007, 02:41 PM
Mayfair's Avatar
Mayfair
Mayfair is offline
Default RE: truck lacking power
ORIGINAL: jasonreda
UPDATE AToday I got the truck on a lift checked the lines all seemed fine So i dropped the fuel tank with about 8 gallons in it and saw that there was a lot of water in the tank.
WOW, didn't see that one comming. Thanks for sharing it !!
Let us know how things go once you get up and running again for sure !!
Old 05-02-2007, 01:04 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Kev_n_AZ is offline
ORIGINAL: jakebrake
There is an additive to add to the tank that will break down any remaing water. You'll want to add that when you get the tank back in, also I would drain the fuel bowl and change the filter.
diesel kleen, or any other additive that will destroy the H2O.
rememeber to prefill the new fuel filter before installing it.
Old 05-09-2007, 12:51 AM
jasonreda's Avatar
jasonreda
jasonreda is offline
Update I drained the tank and put fresh in Noticed the lift pump wasn't doing to well so i did the factory replacement which relocated th epump to the tank Fairly simple procedure. I filled the tank and added (i believe it was deisel Kleen Can't remember off the top of my head And All is well so far I seem to have my power back also.
Quick Reply: truck lacking power
