HIGH EGT
Old May 3, 2007 | 01:24 AM
UTAH's Avatar
UTAH
Default HIGH EGT
I HAVE THE EDGE WITH MONITOR ON 05 DUALLY AUTO PULLING 13000+ TOY HAULER FIFTH WHEEL TRAILER. LOOKING FOR PRODUCT TO KEEP TRANNY IN 3RD GEAR INSTEAD OF SHIFTING IN AND OUT. I AM ALSO WORRIED ABOUT EXHAUST GAS TEMPS. I CAN REACH 1300 NO PROBLEM. I WOULD APPRECIATE ANY HELP.
Old May 3, 2007 | 01:45 AM
jakebrake's Avatar
jakebrake
Default RE: HIGH EGT
to get the egt's down you'll need to free up the exhaust. Get rid of the stock cat and muffle and put a straight through one in, like an aero 4040. Mayfair can tell you about the aero[&:]. As far as the transmission, you'll probably want to upgrade the torque converter and valve body. This should help with the trans problem.
Old May 3, 2007 | 01:51 AM
steve05ram360's Avatar
steve05ram360
put a switch inline with pin 6 of the tranny connector... this will lockout OD...
Old May 3, 2007 | 11:17 AM
samuk's Avatar
samuk
Would removing the CAT only help?
Old May 3, 2007 | 01:50 PM
plasterman's Avatar
plasterman
I also have an 05 with striat pipe from the turbo back and a true flow intake tube and air filter and the edge with attitude.
When I first got the edge everything was fine. Then I noticed the alarm statered going off for egt's after abouttwo months of use. I took it back towhere I had the edge installed and they replaced the whole unit. Then I took the whole unit out and put an egt gauge to see if it was the truck it's self. Then I took it to the dealer and they tell me that there are no codes every thing is fine. I take the service manager for a ride and before I hit 3dr gear I am 1400 deg. he told me there is nothing from dodge cummins about how hot is too hot so just drive it because your covered for 100,000 miles. ( the stupid A$$)
I still have high egt's even without a load I can get 1450 deg easy with a loadand 1200 deg just normal driving gettingon the on rampof the freeway. I am sure it is my truck but I can't find anyone who can tell me why.
So I guess what I am saying is before you go taking out your edge look at your truck and if you find out let me know.
Old May 3, 2007 | 06:10 PM
DieselDemon's Avatar
DieselDemon
1400 degrees is not an acceptable operating temperature.....lol. You should be injecting methanol if you run that hot all the time.
I can take my 95' and peg a 1600 degree gauge. That's a matter of fuel. If you have a 4 inch exhaust, and a performance intake, my guess is you might need more air and/or it's time for a bigger turbo. Intercooler can become restricted as well. Do you monitor boost?
Here's what an undersized turbo does under heavy load.
One more tip for lower EGT's,............let up on the throttle a little......LOL.
Good luck with your ride.
[IMG]local://upfiles/12792/7769BCC23AC949C2BA18F6992DB4CEFD.jpg[/IMG]
Old May 3, 2007 | 06:19 PM
steve05ram360
plasterman.. could you have a plugged air filter? sounds like your not getting enough air thru your motor... what are your boost levels?
Old May 3, 2007 | 06:29 PM
Mayfair's Avatar
Mayfair
HOLY CRAP !!!!
Old May 3, 2007 | 06:30 PM
Drew's Avatar
Drew
1350 is when you need to start looking at backing out of the throttle. . .heat soaking the turbo at that temp isnt a good thing.
Old May 3, 2007 | 10:53 PM
jakebrake's Avatar
jakebrake
also try running down a gear when you see the temps get up there.
