DTC P0123 Throttle/Pedal Position Sensor A Circuit High Input
Old May 5, 2007 | 04:01 PM
st1100man's Avatar
st1100man
Default DTC P0123 Throttle/Pedal Position Sensor A Circuit High Input
Can anyone explain what might be the cause DTC P0123 (Throttle/Pedal Position Sensor A Circuit High Input. Is it the TPS or whatever supplies the voltage to the TPS, or something else? The check engine light stays on, and I believe I felt a couple of slight misfires, 1-2 miles from the house. [&:]
This is what the code reader gave me.
Report Date: 5-4-2007 (3:54 PM)
Vehicle Year: 2000
Vehicle Make: Dodge
Vehicle Model: Ram 2500
Vehicle Engine Size: 5.9L Diesel
Vehicle Mileage: 84,100
Stored:
MIL ON
MisFire Monitor Complete
Fuel System Monitor Complete
Comprehensive Component Monitor Complete
Catalyst Monitor Not Supported
Heated Catalyst Monitor Not Supported
Evaporative System Monitor Not Supported
Secondary Air System Monitor Not Supported
A/C System Refrigerant Monitor Not Supported
Oxygen Sensor Monitor Not Supported
Oxygen Sensor Heater Monitor Not Supported
EGR System Monitor Not Supported
DTC for which Freeze Frame was Stored P0123
Calculated LOAD Value 7.45 %
Engine Coolant Temp 170.60 °F
Intake Manifold Absolute Pressure 30.12 inHg
Engine RPM 768 rpm
Vehicle Speed Sensor 0.00 mph
Intake Air Temperature 152.60 °F
Absolute Throttle Position 0.00 %
Thanks, Steve
Old May 6, 2007 | 08:15 PM
Drew's Avatar
Drew
Default RE: DTC P0123 Throttle/Pedal Position Sensor A Circuit High Input
your TPS could be going out. . .if you can clear the code see if it will come back.
Old Jul 6, 2007 | 09:06 PM
st1100man's Avatar
st1100man
I cleaned the TPS plug in contacts, and worked the throttle fully numerous times with the engine off. I was then able to reset the truck computer, the check engine light went out, and my OBD2 reader went from red l.e.d. to yellow
