This morning the ABS and brake light started coming on and staying on on a friends '94 CTD. He says that when he's hauling his trailer he's got trailer brakes when he manually uses the brake box, but nothing when he uses the brake pedal. I know in the '98 and above its normally the speed sensor that you change, I'm just not sure with the '97 and lower. Thanks in advance for any help.
RE: '94 w/ ABS and Brake Light Starting To Come On
I'n not sure how the older ones work. . .but there could be a pressure transducer on the brake line or the master cylinder that has gone out that works the brakes. . .
