my turbo froze up
Old May 11, 2007 | 08:11 PM
cptdarel's Avatar
cptdarel
Default my turbo froze up
where can one get a turbo kit to O/H a turbo, i heard it's a piece of cake, any ideas.
Darrell
Old May 11, 2007 | 08:23 PM
Mayfair's Avatar
Mayfair
Default RE: my turbo froze up
You're in luck ... I hear that Triton has one comming up for sale soon !!
Old May 12, 2007 | 01:01 AM
jakebrake's Avatar
jakebrake
I am assuming your talking about a cartridge (just the center section). You used to be able to get them directly from cummins, but I think that they quit doing that because of warrenty issues. You'll probably endup with either a reman on a new piece.
Old May 12, 2007 | 01:35 PM
GFB's Avatar
GFB
Depends how bad it is. If it froze up, chances are your turbine shaft is toast. You'd be better off buying a new CHRA instead of a rebuild kit. If you do rebuild it yourself, index the shaft and compressor because they are balanced as a rotating assembly. If you do not realign them exacly how they were, your turbo will not be balanced and will likely fail or grenade before too long. If you have no experience rebuilding turbos I would suggest having a turbo repair shop do it.
