Does any1 add additives to their tank?
Old May 17, 2007 | 12:32 AM
sallyman1's Avatar
sallyman1
Default Does any1 add additives to their tank?
any one add additives to their tank other than antigel in winter? any conditioners or anything. I have a 2004 5.9l 2500
Old May 17, 2007 | 12:45 AM
JotiGrains's Avatar
JotiGrains
Default RE: Does any1 add additives to their tank?
I personally don't add anything, but most people on this forum do.
Old May 17, 2007 | 12:47 AM
sallyman1's Avatar
sallyman1
just conditioners? is there anything a person should stay away from from adding? any bad productsd out there?
aka_chewy's Avatar
aka_chewy
You will definitley get a lot of opinions about this one. I use to run Drew's brew and the only thing I noticed was the motor was a little quieter. I haven't used it for about 10,000 miles now and don't really see any difference. I will run anti-gel in the winter.
Old May 17, 2007 | 02:14 AM
Super Dave's Avatar
Super Dave
Based on my experiance thus far with my 04, the Power Service (available at wally world) made a big difference.
My truck had 54K on it when I got it. At 70 MPH using the cruise I got 17 MPG. After two tanks adding the PS (and MMO), it went to 23 MPG at 70 MPH using the cruise. This all happened within 2 days driving from Dallas to SLC Utah.
Now I think that the improvement was due to the injector cleaning effect of the PS, not any magical properties that made it get better mileage. When this bottle runs out, I will stop adding anything and see what happens. I do forsee myself adding PS every few tanks of fuel to keep things clean.
Old May 17, 2007 | 03:04 AM
Mayfair's Avatar
Mayfair
Funny you should ask .... tonight I JUST added 1 oz of 2 stroke motor oil per gallon. Basically I got 26 gallons of fuel, so i put 26 ozs of 2 stroke in there. I'm adding it to help keep the lift pump and injector pump lubricated. It would be a big plus if i also gained some mpg's since my last 3 tanks with the new FASS installed and not uning any additives at all only gets me 13.6 consistantly.
Old May 17, 2007 | 03:44 AM
JotiGrains's Avatar
JotiGrains
6 MPG better?!
What does PS and MMO stand for, and where can I get some?!
Old May 17, 2007 | 04:00 AM
Mayfair's Avatar
Mayfair
PS = Power Service and MMO = Marvel Mystery Oil
Both are available at any Walmart
Old May 17, 2007 | 09:41 AM
HankL's Avatar
HankL
No major diesel engine maker
Cummins, Cat, DD, Navistar, Isuzu
recommends putting either
Marvel Mystery Oil or ATF
into today's diesel fuel.
Most don't recommend any additive
but I believe I read that GM is ok'ing
the newest year 2007 formulations of
Stanadyne and Racor additives for the
Duramax.
Old May 17, 2007 | 12:58 PM
roadrnnr's Avatar
roadrnnr
Stanadyne.
Dealer recomended I put it in. Truck is new so not sure if it is doing anything. I am going to stop when current supply runs out and compare.
