I'm 2 strokin now ...
Old May 17, 2007 | 03:54 PM
  #21
Drew's Avatar
Drew
Default RE: I'm 2 strokin now ...
that stop and go is what will tear you up. . .get out and open her up and you'll see you mileage go up.
besides I'm gunna first start off with 8ozPS and 4oz 2st. and go up from there. since Ive got smoe mileage now and things have been worn in well, I guess a true test can start.
Old May 17, 2007 | 04:34 PM
  #22
Mayfair's Avatar
Mayfair
ORIGINAL: Drew
LMAO .... I guess you missed my question in my other post about getting rid of the limiter. I DO get on it !! Rarely do I cruise below 70-75 mph on I-95. It's like my own little slice of freedom. Because Ihave my nuts in a vice with that light to light stuff when I FINALLY get to the highway I cut loose.
LOL ... If all I had to do was "get on it" to increase my mileage, I'd be getting 30mpg right now, not 13.6
Old May 17, 2007 | 04:48 PM
  #23
Drew's Avatar
Drew
75+. . .no wonder your only getting 13-14
Old May 17, 2007 | 04:58 PM
  #24
Mayfair's Avatar
Mayfair
90% of my driving is still that light to light stuff the other 10% is highway. Anyway you slice it, I'm screwed ....
I WAS up to mid 14's though in the winter using your Brew. I haven't totally bailed on that idea. I just really like the sound of the benefits of using the 2 stroke.
How come you're still going to use the PS with the 2 stroke, and why the low mixture? On MM73's site he claims that one counteracts the other, meaning that the PS breaks down the 2 stroke because it has thinners and such in it. "I" of course, am lost in the whole thing.
Old May 17, 2007 | 05:01 PM
  #25
Drew's Avatar
Drew
PS wont break down the 2 stroke, besides, diesel will thin out 2 stoke as well. . .what you are after are the increase lube properties. . .I still have some MMO around and am going to try different mixes
Old May 17, 2007 | 05:21 PM
  #26
Mayfair's Avatar
Mayfair
ORIGINAL: Drew
Old May 17, 2007 | 09:11 PM
  #27
rbmchief's Avatar
rbmchief
mayfair, that was mostly a cut and paste from mm73. every third or fourth tank i run just stanadyne with the 2 stroke just to keep things cleaned out a bit.
Old May 17, 2007 | 10:44 PM
  #28
loveshackhauler's Avatar
loveshackhauler
Gotta add my 2 cents worth here.
I've been using drew's brew for the last 4,000 miles, had noticable change when I started using it (increased mpg 2mpg, less noise, more power)
I've also had the pleasure of paying for a lift pump and a pressure pump for a ford - and don't EVER want to do it again.
I'm pretty much thinking anything that can assist with lubrication is worth a try.
Old May 17, 2007 | 10:57 PM
  #29
mce's Avatar
mce
ORIGINAL: DBLR
I can see the 2 cycle oil helping with lube but not your mileage as I understand it has a higher flash point then diesel fuel. But then you do have an engine without a lot of computer control stuff like I have so you might see a small increase in mpg.
For my truck the best way to get better mpg is to use 5 oz of Lucas fuel treatment per tank. I also use 4oz of Lucas in every tank of gas in my wife’s car and we gained 3 mpg so I think its worth the cost of 23 cents per oz.
DBLR, which Lucas product do you use?
Old May 18, 2007 | 05:22 AM
  #30
Mayfair's Avatar
Mayfair
ORIGINAL: rbmchief
How do you mix it up?
What's the ratio ??
