leveling kit help
Old May 19, 2007 | 12:32 AM
bigassdodge's Avatar
bigassdodge
Default leveling kit help
i have a 06 quad cab, with 17x9 helo's ( they have 1 more inch of backspacing than stock). i tired to mount a set of 315/70r17 today and they r rubbing on the back of the front fender where the mudflap mounts. my question is will the leveling kit fix this or do i need to buy a lift. also if the levling kit fixes this should i go with a kore system or go with one on ebay.
i found one on ebay for 86, no shocks, dont know if i need new shocks or not, its made by top gun customz. does anyone know anything about this manufacturer?
Old May 19, 2007 | 12:44 AM
SpLaT's Avatar
SpLaT
Default RE: leveling kit help
My 05 QC with Dick Cepek FC II 325/50R20 mountedon Demoda 20x10 rub the mud flaps on mine, only do to deformed flapand are thicker then most flaps.I do have 3" lift up front with the Kore Chase system. A simple cheap2"levelling kit ought to solve your problem.
Old May 19, 2007 | 12:41 PM
bigassdodge
can you run the leveling kit without changing your shocks?
Old May 19, 2007 | 12:59 PM
FroneDaddy's Avatar
FroneDaddy
Yea
Old May 19, 2007 | 01:09 PM
bigassdodge
is 2 inch leveling kit enough to run these tires with no rub?
Old May 21, 2007 | 07:41 PM
bigassdodge
is anyone else on this site running helo's 17x9
Old May 22, 2007 | 12:58 AM
moconst's Avatar
moconst
I have stock rims with 33/12.50/17 cooper muds no rubbing at all, but i have the leveling kit. Im sure if you level you will have no more problems. You will be suprised what 2 lil inches does for clearance.
Old May 22, 2007 | 01:03 AM
JimmyDiablo's Avatar
JimmyDiablo
I am running stock rims with 315/70/17's bfg all terrain ko's I have a leveling kit and it is perfect on and off road.
Old May 22, 2007 | 11:42 PM
bigassdodge
i just hope with the leveling kit and the offset wheels i can run these 315/70 without rubbing
