Dodge 600 Diesel--- True 600 or not?
Old Sep 16, 2004 | 02:29 AM
kz5fhz's Avatar
kz5fhz
Default Dodge 600 Diesel--- True 600 or not?
I recently bought a 04 2500 Diesel 4X4. I was told by the "Sales Person" that it was the new 600.
I have been told that the 600 is marked on the outside under the Cummings Emblem. How do you tell if it is an actual 600 or not? The date of MFG on the Engine is stated 02/03/04.
Please let me know how I can tell if it has a True "600" or not.
Old Sep 17, 2004 | 02:11 AM
jhalfhill's Avatar
jhalfhill
Default RE: Dodge 600 Diesel--- True 600 or not?
Get a serial number off the engine and contat either Dodge or Cummins.
Old Sep 17, 2004 | 02:12 AM
jhalfhill's Avatar
jhalfhill
Or try VIN number
Old Sep 17, 2004 | 02:13 AM
94ram4x4 5.9's Avatar
94ram4x4 5.9
are you talking about an engine model, or the amount of torque it produces?
Old Sep 18, 2004 | 01:18 AM
dodgemech's Avatar
dodgemech
It's an 04, it should be the 600.
Old Sep 18, 2004 | 04:51 AM
RcBandit28's Avatar
RcBandit28
Not true....the 600 came out half way through the 04 model year...if you have an early 04 it could be what was then known as the High-Output. However, it is NOT on the badge on the front fenders....they all just say Cummins Turbo Diesel....Check out your window sticker, or ask your service dept to check your VIN number.
Old Sep 18, 2004 | 07:01 PM
dodgemech's Avatar
dodgemech
Let me re-phrase that, I understood that he recently bought meant he has purchased within the last few weeks a new Cummins truck. Around here that means it is fresh off the line because they don't sit on the lot for more than a couple weeks. So if it is a fresh built Cummins 04 then it is almost certainly a 600.
Old Sep 19, 2004 | 04:44 AM
RcBandit28's Avatar
RcBandit28
agreed.
Old Sep 19, 2004 | 01:19 PM
Drew's Avatar
Drew
I'll look on the data plate on my engine again and check to see the manufactureing date. I know mine is the 600.
I believe another way to tell is if on the data plate it states it's 325 horse since the 555 lb-ft engine only had about 300 horse, or 290, something around there.
Old Feb 18, 2005 | 06:41 PM
kz5fhz's Avatar
kz5fhz
Do you believe that the 325 HP Rating for the 600 is correct. I looked at my Tag and it did say 325 HP @ 2900 RPM
