swap
Old May 30, 2007 | 10:37 AM
madskycc's Avatar
madskycc
Default RE: swap
What I plan on is. Laying frame on 20. Put a diesel in. The rear endthink i am going to use is a Dana 60 or Dana 44.Any ways i love the cummins 5.9 diesel and easy to make great power.What my goal isto bulitareliable steert truck that looks good and haul ***. In one word
sleeper
Old May 30, 2007 | 12:13 PM
Drew's Avatar
Drew
Default RE: swap
Ive seen a 5.9 in a dakota RCSB. . .only problem the guy had was keeping the rear tires on the rims. . .he had a problem with them constantly blowing.
Jake is right about the 5.9 w/P7100. . .all you need is a wire for the shut-off solenoid, and the wireing for the starter. everything else is mechanical.
you will need beefier motor mounts, and beef up the front end a bit. however a 96 5.9 w/ a built auto would haul some serious butt.
Old May 30, 2007 | 04:01 PM
tdmopar59's Avatar
tdmopar59
Default RE: swap
the airbag suspension......? do you thing that has the strength for such a heavy motor?
Old May 30, 2007 | 05:44 PM
Drew's Avatar
Drew
Default RE: swap
yup. . .you would be surprized how much weight they can take.
Old May 30, 2007 | 11:37 PM
jakebrake's Avatar
jakebrake
Default RE: swap
Heck, most of the big rigs are switching to air bags. Don't use a 44 for the rear, you'll want the 60. You'll blow up the 44 the first time you get traction.
Old Jun 3, 2007 | 05:32 PM
madskycc's Avatar
madskycc
Default RE: swap
Thanx for your help.I plan on use a dana 60 rear with posi and four link setup. The bag will hold up cause they can hadle 2000 lbs per side. I want to make this a autocross lookig truck. I probalby start on in the next few weeks. For now i will be get part round up.
Old Jun 3, 2007 | 07:08 PM
jakebrake's Avatar
jakebrake
Default RE: swap
I can see this thing making it into the half tons someday
http://www.cmdmarine.com/PDFs/4082063_0207.pdf
http://www.cmdmarine.com/qsd4.2.html
Old Jun 3, 2007 | 07:25 PM
bksram3500's Avatar
bksram3500
Default RE: swap
Dealer told me in 2009 they would a a half ton with a
cummins.
Old Jun 3, 2007 | 07:45 PM
jakebrake's Avatar
jakebrake
Default RE: swap
I wonder if it will be the 4.2L. or if they are designing a new one.
Old Jun 3, 2007 | 10:24 PM
Drew's Avatar
Drew
Default RE: swap
4.6L v6and a 5.6L v8
the 4.6L will push about the same juice as a stock 98 and the 5.6L will be rated at around 300hp and 550tq.
