swap
Old May 28, 2007 | 07:07 PM
madskycc's Avatar
madskycc
Default swap
how hard is it to put a 96 5.9 cimmin in to a dakota? How much wiring is involved? I know i gotto change to tank and fuel pump. I have a 97 dakota on airbages and iwant to do something differnt.
Old May 28, 2007 | 08:58 PM
moconst's Avatar
moconst
Default RE: swap
Just put it in the bed, no wiring needed.
Old May 28, 2007 | 09:43 PM
jakebrake's Avatar
jakebrake
Default RE: swap
As far as wiring, there really isn't any to the 96 cummins. Just the shutdown solenoid and the starter is all you need.
Old May 28, 2007 | 10:43 PM
madskycc's Avatar
madskycc
Default RE: swap
What about the glow plugs and the injectors. So your saying only a few wires. Would this swap be wroth my time? What type of fuel pump is need or is the P-7100 pump adequatuate.What about trans anywiring needed?
Old May 28, 2007 | 11:53 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: swap
your gonna have to beef up the front suspension pretty good on it. I would to a Solid front axle swap while your in there
I've looked into putting a 5.9 12 valve cummins in my dak. but I'm just saving up for a ram now. it will be cheaper.
my buddy put a 3.9 cummins in an 88 jeep camanche. and that thing hauls ***! he keeps breaking motor mounts though.
Old May 29, 2007 | 02:50 AM
jakebrake's Avatar
jakebrake
Default RE: swap
that's true a little inline 4 would be a better choice. That would cut down on a lot of weight.
Old May 29, 2007 | 03:13 AM
steve05ram360's Avatar
steve05ram360
Default RE: swap
like this motor? http://www.cummins.com/na/pdf/en/pro...et/4000161.pdf
Old May 29, 2007 | 08:31 PM
jonnymagnum
Default RE: swap
ORIGINAL: steve05ram360
that would work perfect. a lil tuning and you would be all set.
anybody know how easy and how much power you can get outta the lil 3.9's?
Old May 29, 2007 | 10:57 PM
jakebrake's Avatar
jakebrake
Default RE: swap
I was thinking of the old mechanical one. You'd pretty much do the samething to it as the 6 cylinder. As for that one, you'll have to find someone to build a chip.
Old May 30, 2007 | 12:41 AM
jonnymagnum
Default RE: swap
ya, I'd do an old one.. I think my buddys was outta a 60 somethin delivery van. he didnt even rebuild it when he put it in either. just a lil turbo upgrade and he made up mounts for it to bold up the the stock 5spd tranny too.
