goose neck hitch
#21
Here is what NOT to get! It is made by Curt Mfg. and the idots who installed it drilled holes in the frame to mount it to boot!
![](https://dodgeforum.com/albumtn.aspx?size=tn&imgpath=47608-asppg_Gs943901974.jpg)
![](https://dodgeforum.com/albumtn.aspx?size=tn&imgpath=47608-asppg_Fw272286760.jpg)
![](https://dodgeforum.com/albumtn.aspx?size=tn&imgpath=47608-asppg_Xz547428888.jpg)
Unfortunately it was on the truck when I bought it! I like the B& W setup and I have also looked at the Reese/Drawtite signature series mounting that allows you use the same frame to pull either a 5th wheel or Gooseneck!
#22
ORIGINAL: 1Normy
![Wink](https://dodgeforum.com/forum/images/smilies/wink.gif)
What don't you like about it? You should've seen the one that was in my truck whenI got it. They welded a piece of 1/4" plate between the frame, it had a threaded bung in it and the bed had one hole drilled for the ball to thread in the plate, I don't think I would tow with it.
[IMG]local://upfiles/57704/A998FC9534B14470BBF2B9AF6DFAC105.jpg[/IMG]
[IMG]local://upfiles/57704/2A39398F460B4AC29F347F4B09A1D820.jpg[/IMG]
[IMG]local://upfiles/57704/DFF0A945D5334FD9B0578DA03207A309.jpg[/IMG]
#23
ORIGINAL: FroneDaddy
I doubt I will ever use it, but I wouldn't be afraid to use it if the trailer wasn't terribly heavy. I took the ball out and made a drop-in plug to fill the hole so I can load sand or gravel in the the bed without it all faling through like an hour glass
I keep the ball under the back seat just in case.
#24
Yea, you know what, mine is c channel also. It looks like it was fabbed, but, the piece of c channel appears that is what it is for, there's no nut welded to it. It's thick with a threaded hole in it. I took the ball out of mine too, that thing was in there good. I had to use an 18" pipe wrench and a 10' piece of 1/2" pipe extension, used a torch for heat and it still took 1/2 hour to get it loose.
