oil question
as long as it is CJ-5 (I think) compliant your good. . .
besides I've been useing 15w40 all the time in mine. the 5w40 is good for winter since it is a bit thinner. helps with start-up lubrication during cold temps.
ORIGINAL: Welder597
Will using 15-w-40 synthetic(royal purple) be alright in my truck? I accidently ordered that instead of 5-w-40.
Also if you do use the new CJ-4 oil if you burn any LSD you will need to shorten your oil drain interval by up to 50% as it does not hold up well when you burn LSD do to the higher sulfer content. One other thing about CJ-4 oil it is not made to run extended oil drain intervals do to the lower TBN number it has.
