What is capacity of transfer case?
Old Jun 15, 2007 | 12:54 AM
sallyman1's Avatar
sallyman1
Default What is capacity of transfer case?
I have a 2004 dodge 2500 CTD 4X4. What is the capacity of the transfer case roughly? 3 litres or 4? I wanna buy the amsoil ATF before draining old stuff so i wanna know b4 hand. Thanks......PS which plug is to drain i see 2 that could possibly be drains?
Old Jun 15, 2007 | 01:08 AM
s15996b's Avatar
s15996b
Default RE: What is capacity of transfer case?
buy 4 qts, they usually take 3 plus. the drain and fill plugs are on the rear of the case left side, the drain is the one at the bottom. the fill plug is above it half way up. fill it till it runs out then plug it.
Old Jun 15, 2007 | 01:30 AM
sallyman1's Avatar
sallyman1
ok. so 4 litres
Old Jun 15, 2007 | 05:29 AM
Bigriver's Avatar
Bigriver
Thanks for the info. A few weeks ago, I upgraded to an ATS and had filled it with Amsoil ATF. After further thought, I decided to also replace the transfer fluid with Amsoil soon. Timing was right on seeing this post !!
[IMG]local://upfiles/53127/56A0FAA2BDD44C278E027079C0D74A88.jpg[/IMG]
Old Jun 15, 2007 | 08:57 AM
Joel_MD's Avatar
Joel_MD
I was just looking at the Amsoil online application guide. It shows the capacity of a few different transfer cases, and they hold either 3.4 or 4.0 pints. So it seems to me that 2 quarts would be adequate.
Old Jun 15, 2007 | 10:47 AM
Drew's Avatar
Drew
if the transfer heald 4 liters that thing would be HUGE!!!!!!
4 pints is all you need. . .2 quarts
http://www.dodgeram.org/tech/specs/tranfer_case.htm
NV271
Old Jun 15, 2007 | 11:09 AM
sallyman1's Avatar
sallyman1
thanks
Old Jun 15, 2007 | 01:32 PM
Bigriver's Avatar
Bigriver
Sounds about right, I decided to drain the transfer case and make sure to have enough on hand to fill to the overflow line.
