Bad Fuel Injectors???
RE: Bad Fuel Injectors???
ORIGINAL: Drew
sometimes yea, sometimes no. . .
if it is found there is water in the tank then yea, you probably could, however with the gunk that is normal to diesel I doubt it.
depending on the age of the stations tanks, debris and water will foul you up.
kinda like drinkin the last of the milk you think is good....till the chunks hit the back of your throat!
Cowboy Bob,
thanks, I called Fass and ordered the correct fuel pump, guna be about $800 for it, a water seperator and filter. The general concensus is that I have MAJOR blockages at the injectors, so they are also trying to find a set of Stage 1 Injectors that'll fit the truck. Has anyone here upgraded a 2006 fuel injector? They seem to be hard to find.......
No one is making or supplying aftermarket injectors as of yet. However i did find a place in Washington State that will remanufacture mine to the specs that i what. So thats the route were taking, guna make my old damaged injectors the equivalent of the stage 1 that you can buy for the 04's I am told that I should see a 60hp gain. While I'm at it going to go with the Fass Fuel System - custom built to my spec psi, and an extra large motor to handle the thickness of the veggie oil - . And seeing as how my warrenty is shot, guna rip out the air box and install a bully dog progammer. Hmm.... 325hp stock, + 60hp injectors + 10hp new air filter + 140hp Bully Dog = 535HP "supposedly" Yup that should pretty much destroy my tranny........ LOL
Mayfair..... if you have pics then yes I'd appreciate them.
ORIGINAL: GravyTrain
Here are the links ...
Don't pay attention to the wireing part in this link, it is the old / wrong way
http://ramchargercentral.com/index.p...owtoshow;id=91
This one's pretty good.
http://www.cumminsforum.com/cftruck/fass_install.php
The first pic here is Jakes set up ...
[IMG]local://upfiles/42139/84F1B9B157A24CCD922E354B6938386E.jpg[/IMG]
[IMG]local://upfiles/42139/9085FDAAFAB64F45A1870624C113A794.jpg[/IMG]
