Cold air intake question
Old Jun 19, 2007 | 01:15 AM
moconst's Avatar
moconst
Default Cold air intake question
I have an air raid cold air intake, My edge is tellin me my intake air temp is usually around 100 degrees. Why is it so high? thanks
Old Jun 19, 2007 | 01:43 AM
cookie_monstr's Avatar
cookie_monstr
Default RE: Cold air intake question
the engine bay is hot. so ur intake air will run quite warm. mine reads about the same 100... more or less...but i live in houston.
Old Jun 19, 2007 | 01:46 AM
Super Dave's Avatar
Super Dave
On the highway, my Edge shows the intake temp always 12 degrees hotter than the thermometer on the overhead. I guess it's just due to the under hood temps.
Old Jun 19, 2007 | 01:51 AM
Drew's Avatar
Drew
actualy 100F is good. . .go to 110-120 and you'll see performance drop off.
Old Jun 19, 2007 | 02:01 AM
steve05ram360's Avatar
steve05ram360
lol, 100~105 is awesome, gives the best performance IMO... I've seen 130~135 on my edge when I had it... remember Sacramento... I wonder what Sharky gets his up to...
Old Jun 19, 2007 | 03:23 AM
R0oster31's Avatar
R0oster31
What is your boost at going down the highway? You're cold air intake is doing just fine if your temps are that. Mine where in the 90's or so cruising at 80 if I was only pulling 6 pounds of boost or less. The reason they are warmer than ambient is because you are pulling a little boost, compression makes things heat up. The aftercooler takes some of the heat out, but thermal systems are never 100 percent efficient. That's just my 2 cents.
Old Jun 19, 2007 | 04:15 AM
Kev_n_AZ's Avatar
Kev_n_AZ
the only way to drop the intake temp would be to close up the new filter housing and port it directly to the front grill. this would eliminate most of the engine compartment heat from direct contact to the filter. my 93 has the stock filter housing, it has the intake on the bottom just below the headlight.
