A/C problem
Old Jun 19, 2007 | 04:46 PM
usafr's Avatar
usafr
Default A/C problem
My A/C will come on and produce cold air, it's really a problem with the fan. I won't blow out of the vents on the dash. I will also not switch to defrost, it will however kinda switch to the floor vents. It seems as if the selector in the dash is stuck or something. I'm wondering if I have a bad switch on the a/c controls or something. What do u guys think? I don't really have time to put it in the shop rite now, so I'd like to fix it myself.
Old Jun 19, 2007 | 04:54 PM
SoNauty's Avatar
SoNauty
Default RE: A/C problem
hey usafr!
Check my post here:
https://dodgeforum.com/m_853349/tm.htm
My A/C blows cold but it sure doesn't circulate the air. I was told by the stealership that I was **** outta luck... that's how it was designed. I REALLY hope that's not the case!
Good Luck... keep in touch if you find a solution!
Old Jun 19, 2007 | 05:10 PM
usafr's Avatar
usafr
Mine was blowing just fine bofore and this morning it just all of a sudden stopped. I think the selector switch may be bad, b/c it will not switch between panel and defrost. I'ts like it's stuck where it's at.
Old Jun 19, 2007 | 05:12 PM
Drew's Avatar
Drew
Mike. . .I'm wondering if the actuator for the blend door isnt moving like it should, or if the door itself is broken.
if that is the case then you'll have to yank out the entire dash
Old Jun 19, 2007 | 05:46 PM
usafr's Avatar
usafr
That sounds kinda like what I was thinking Drew. When I switch the selector I don't hear anything moving in the dash to indicate that it's trying to switch flow direction.
