05 transmission problems
Old Jun 25, 2007 | 02:44 AM
Charger7022's Avatar
Charger7022
Default 05 transmission problems
Hi im new to the forum just got a used 05 2500 quad cab CTDbought 3 months ago my problem is from a stop goin real slow threw like a neiborhood it seems to go back and forth between 1st and 2nd really fast till i step on the gas than it goes to 1st than as long as i stay on the gas it goes threw all 4 gears fine no slipping. the second problem is when im crusing about 35-40 im guessing and i stomp the gas theres a long pause like slipping between grears like 2-4 seconds i was wondering is it the tranny or Torque converter and what can i do to fix the problem,only got 49,000 on the truck but just put a 5"turbo back exhaust with no cat and my bullydog power pup with outlook monitor will be in this week so i dont think the dealer will help much
Old Jun 25, 2007 | 11:28 AM
JimmyDiablo's Avatar
JimmyDiablo
Default RE: 05 transmission problems
Was it ever serviced? Filter may be clogged (two filters)
Old Jun 25, 2007 | 12:14 PM
steve05ram360's Avatar
steve05ram360
sounds like a valve body problem... mines getting swapped out today for the same 1st/2nd gear problem. I will let you know how it goes... there is a possibility it could be the throttle position sensor getting noisy
Welcome to DF!
Old Jun 25, 2007 | 02:04 PM
DBLR's Avatar
DBLR
Steve.
I thought you already had a built VB in your trans before it was rebuilt? So what did you do to it to make it give you1-2 gear hunting problems?
Old Jun 25, 2007 | 03:19 PM
steve05ram360
I did, I dont have any confidence in it right now. when we installed it and adjusted the bands, it was good for a while then started acting up again in 2nd gear. swapping it out will either fix it or tell me there is another problem that is not the valve body. The tranny shop owner is telling me the kit he's installing into the valve body will firm up the shifts even more than the one I have now. time will tell.. it's supposed to be ready to go now for an install today.
Old Jun 25, 2007 | 06:47 PM
Charger7022
dont know if it was serviced or not i know the oil was always changed that showed up on the carfax befor i bought it ill try a fluid change what do you guys recomend for a filter and fluid ??
Old Jun 26, 2007 | 03:40 PM
DBLR's Avatar
DBLR
ORIGINAL: Charger7022
I've used Amsoil trans fluid in every Dodge I've owned for the past 7 years with out any problems. As for the filter I used one from Dodge on my truck when I changed it out last month but the Wix filter is a good one too.
Old Jun 30, 2007 | 12:26 AM
Charger7022
stoped at the dealer to make and appoinment funny there two tranny guys are booked for a week lol. my old neibor is the service manager and is pretty cool, i went straight to him and he wasent to sure when i explained whats going on he said the tranny guys are gonna have to look at it. he hook me up last time when i my rearend went out in my 04 hemi no questions asked so i hope he helps me out this time we will see. i have no cat on the truck and i am going to put the downloader back to stock we'll see what happens on july 9[/align]
