So after some Q & A with edge, they said that the juice module has boost fooling built into it. So Speakle it seems you already have it. By the way I was payin att to my boost today. When I get on it it about 25-28. But normally around 5-10 under normal driving
I was going to say that your edge already has it built in... there is a setting for max boost on your edge and it may be set at 25 psi now. they suggest 36 as your max setting. have a look thru the menus for it and let us know what it was set to.
Set it to stock today, hit 39psi no problem. Wastegate must open at 40 because I never see it. I changed my setting to 40psi on the edge because the damn alarm kept going off even under moderately hard acceleration.
