major problems with 6.7 cummins
Old Aug 31, 2007 | 08:45 PM
  #31
olkutt's Avatar
olkutt
Default RE: major problems with 6.7 cummins
just back from shop (138mi)again eng. light came on and lost boost,jake, after talking to mech&tec staff their going to try a new turbo. the tec pepole their hinted that they have a problem but not sure where it is coming from,some in the soft ware others the turbo(thanks alot). will post after tues. when turbo is replaced.
Old Aug 31, 2007 | 09:17 PM
  #32
GARAM1's Avatar
GARAM1
Junior Member
I have 2007 - 2500 with 6.7L Quad Cab, Auto, 2WD, 3.73 axle with around 2800 miles. The Malfunction Indicator Light (MIL) has came on 3 times and the dealer has just reset the computer (2 times). They indicated a problem/error code waswith the turbo temperature being read by the computer. Of course the typical questions about fueling up and properly tightening the fuel cap. I've had no problems wth the running of the truck. It's going to service on Tuesday to further evaluate the MIL.
Old Sep 4, 2007 | 03:23 PM
  #33
GARAM1's Avatar
GARAM1
Junior Member
ORIGINAL: GARAM1
Dealer took 4 hours to diagnosis the problem and code. I believe it was code P245A. They finally cleaned the EGR valve and told me not to idle too much as it would build up soot on the EGR valve.
Old Sep 7, 2007 | 02:15 PM
  #34
olkutt's Avatar
olkutt
just got mine back from shop,they put in a new turbo and a upgraded program( they wouldnt give the code ) hopfully this does the trick.
with the bad turbo i had no boost or brake action and the powre was low. mpg at 13.5
new turbo is still stiff and not coming up but that will free up in the next wk,hopefully the mpg will go back two 18mpg+ back and forth to work.
Old Jan 16, 2008 | 09:14 PM
  #35
rvert10's Avatar
rvert10
I traded my 2000 5.9, 5 speed manual for the 2007 6.7 auto. although I only have 305 mi. its a sweet ride
It will be interesting to see how it tows 14k. My only concern is mpg right now
Old Jan 16, 2008 | 09:23 PM
  #36
04QC4X4's Avatar
04QC4X4
It will tow just fine. You'll have to wait a while for the mileage, but it will come as you break the engine in. I've heard plenty of people are getting decent mileage with the 6.7s. It may not be as good as your 2000, but I bet you'll be happy with the new found power.
Old Apr 19, 2008 | 11:05 PM
  #37
tinspot's Avatar
tinspot
my 6.7 continues to have problems. I pull a loaded goosneck trailer in stop and go houston traffic. I also have several hot shot companies that haul for me and all their 07 cummins have the same problem even after the tsb up date compliance! Is there a rev b or c? Use of the jake brake down a long high bridge causes the emission warning light to come on every time.
Old Apr 20, 2008 | 01:04 AM
  #38
Az2500Cummins08's Avatar
Az2500Cummins08
Maybe you are not driving it right. There must be something you are doing wrong, or the dealership did wrong. I tow with mine all the time, and daily drive, and I have no probs.
Old Apr 20, 2008 | 01:07 AM
  #39
RamItOne's Avatar
RamItOne
did you check the spark plugs???????
Old Apr 20, 2008 | 02:09 AM
  #40
twiessmer's Avatar
twiessmer
why did he replace them all with ford gas burners if the trucks are new they must have a warnty.. what did he do with all the trucks did dodge buy them back or something. just dosent add up.
