How much boost is everyone getting?
Old Jun 28, 2007 | 01:40 AM
jakebrake's Avatar
jakebrake
Default RE: How much boost is everyone getting?
Who installed your edge?
Old Jun 28, 2007 | 01:57 AM
speakle's Avatar
speakle
I did. Like I said, I am seeing 39psi with it on the stock setting. This may be normal for a 2006 or maybe someone installed a boost fooler? I have pushed it pretty good and nothing bad has happened, turbo sounds differnet than my other 2006 did but there is no cat and a tiny muffler on this one where I had a stock exhaust system before.
Old Jun 28, 2007 | 02:07 AM
jakebrake's Avatar
jakebrake
I'm thinking its got a fooler somewhere still hiding the signal
Old Jun 28, 2007 | 03:02 AM
moconst's Avatar
moconst
Ok, under acceleration... 3rd gear(auto) 2200 rpm's Im getting 34.
Old Jun 28, 2007 | 03:15 AM
speakle's Avatar
speakle
According to boost fooler instructions theypiggybackinto the map sensor plug. Since the edge uses this plug also I am sure I would have noticed this! I will check again tomorrow. Moconst, have you checked yoru boost at the upper 2000 rpm range? This is where I see the high boost numbers.
Old Jun 28, 2007 | 03:36 AM
speakle's Avatar
speakle
Ok, just went outside in my underwear with a flash light and climbed up into the engine compartment and there is no boost fooler on the map sensor plug.
Old Jun 28, 2007 | 03:41 AM
jakebrake's Avatar
jakebrake
Let that turbo sing
Old Jun 28, 2007 | 03:44 AM
speakle's Avatar
speakle
I am just concerned. The truck doesnt seem to be as fast as it should be judging from my last one, I realize this one has more weight with the 4x4 but that shouldnt matter that much. I am hoping when I put my aero on next week it will make a huge difference. My other thought was that if this turbo is over boosting wouldnt that hurt power as well?
Old Jun 28, 2007 | 03:46 AM
Mayfair's Avatar
Mayfair
ORIGINAL: speakle
[IMG]local://upfiles/42139/0830F20C78934432B973BE938335DEAB.gif[/IMG]
[IMG]local://upfiles/42139/D698D1DF46BD4410925A36FBD4131648.gif[/IMG]
[IMG]local://upfiles/42139/2E2C525930BE4C3DA9BF829BAFD8DBCB.gif[/IMG]
Old Jun 28, 2007 | 03:49 AM
speakle's Avatar
speakle
I was waiting for someone to comment on that...I should have known who would be first.
