I need gauge help fellas !!
Old Jul 4, 2007 | 03:40 AM
Mayfair's Avatar
Mayfair
Default I need gauge help fellas !!
I'm about ready to cheat, andI don't want to.
I can't find the wire to splice into for the lights to save my life. I'll bet I've spent almost 2 hours trying to find it. It got to the point whereI just started poking random wires and the next thing you know my fuel pump starts running, sounded like my emergency brake gave way, all kinds of stuff. I stopped right there for fear the air bag would deploy !!
I thought that maybe I could tap into either my ashtray light or the cup holder light but neither one lit the test light. Both bulbs were out though, do you think that had something to do with not getting the test light to light? Like, if a bulb is out does it stop the connection?
I'm almost done and it's going pretty good. My boost gauge doesn't work though. I pulled the gauge and it looked like the line might have gotten kinked, so I hafta get a new ferrel tomorrow and try it again.
Does it take a while to give you a reading?
Thanks in advance !!
Old Jul 4, 2007 | 07:28 AM
FroneDaddy's Avatar
FroneDaddy
Default RE: I need gauge help fellas !!
READ DOWN AND TAP INTO THE PARKING LIGHTS WIRE..............
1998 Dodge Ram Pickup Security Information
Constant 12V+
Pink/Black or Red
Ignition Switch Harness
Starter
Yellow
Ignition
Dark Blue
Ignition 2
Black/White
Accessory
Black/Orange
Ignition Switch Harness (Heat/AC)
Tach
Black/Gray
PCM Passenger's Rear of Engine on Firewall
Neutral Safety Wire
Black/White (-)
Brake Switch
White/Tan
Brake Switch or Ignition Switch Harness
Trunk Pin
n/a
Parking Lights
Black/Yellow (+)
Large White Connector above Brake Pedal
Head Lamp
Light Green/Black
Steering Column
Factory Disarm
Light Green/Orange (-)
24 Pin Connector behind Driver's Dash
Door Trigger
Yellow (-)
Driver's Kick Panel Yellow Connector or Light Switch
Door Lock
Orange/Purple
10 Pin Connector Driver's Kick Panel
Door Unlock
Pink/Purple
Reverse Polarity
Horn Wire
Black/Red (-)
74 Pin Connector behind Driver's Dash
Windows Up
LF=Light Blue, RF=Brown/White
Windows Down
LF=White, RF=Purple/White
Old Jul 4, 2007 | 10:05 AM
Mayfair's Avatar
Mayfair
That's AWESOME, and I'll look for it, but that will only turn the gauges on and off with the lights right? They won't dim though with the dash right?
Black and yellow wire ... GOT IT !!
Thanks !!
Old Jul 4, 2007 | 10:07 AM
FroneDaddy's Avatar
FroneDaddy
Right.......no dim
Old Jul 4, 2007 | 10:09 AM
Mayfair's Avatar
Mayfair
Dude I'm going out there right now in my undies to check it out .... BRB
Old Jul 4, 2007 | 10:11 AM
speakle's Avatar
speakle
[:'(]LOL
Old Jul 4, 2007 | 10:12 AM
FroneDaddy's Avatar
FroneDaddy
Hahahahah, a white guy in his tighty whities in Philly laying on the floor boards of his truck, I bet the neighbors love you.......besides that it a chilly day here in PA
Old Jul 4, 2007 | 10:41 AM
Mayfair's Avatar
Mayfair
[sm=hail.gif][sm=hail.gif][sm=hail.gif][sm=hail.gif][sm=hail.gif] Frone, you da MAN !!!! [sm=hail.gif][sm=hail.gif][sm=hail.gif][sm=hail.gif][sm=hail.gif]
I just got back from outside and it's done. 100% of my problem was that whoever installed my alarm system left a NIGHTMARE balll of wire tucked under the dash.EVERYTHING is covered with this ball and they cut their wires so short that you can't really pull it open. I wa also afriad to pull too hard because I didn't want to pull the wires apart. I'd NEVER be able to figure out where they went !!
Thanks again Frone !!!
How about the boost gauge? Does it take a while to register ( show a reading ) ?
Old Jul 4, 2007 | 12:06 PM
mopar98's Avatar
mopar98
Where'd ya mount it ?
Old Jul 4, 2007 | 12:19 PM
jakebrake's Avatar
jakebrake
Boost should respond pretty quick. I'll bet you gotta pinched spot or a kink in your hose
