Autometer A-pillar and gauges install w / PICS !!
Old Jan 3, 2008 | 01:49 AM
  #41
Mayfair's Avatar
Mayfair
Default RE: Autometer A-pillar and gauges install w / PICS !!
Well, whatI did was just keep going back and forth from the truck to the workbench until I got it to fit.
Originally, I couldn't get it to fit because of the speaker, so I trimmed that section out. Then,I re-installed the stock pillar and slid the new pillar over it with duct tape temporarily holding it together. It was when i couldn't slide it all of the way down that I realized that it was now toofat at the bottom so I trimmed the bottom of the original. Back and forth back and forth until I got it to work. I'm sure I made it harder thanit needed to be, but I got it to finally fit and work. Just take your time and you'll be fine. Take a look at the pics I postedon the first page as a guide. Just remember to be gentlewhen removing and re-installing the pillar. Those clips are kinda dainty.
Old Jan 3, 2008 | 01:32 PM
  #42
chet's Avatar
chet
ok this is what i have got so far. I was wondering about the back side of the pillar it doest match up perfect but the back side tucks in between the windshield and the a pillar so you cant really notice it ? also i test fit and its a tight fit to get the bottom pin in the hole, but i dont think there is anything i can cut to make it easier its just the added bulkiness of the cover.
Old Jan 3, 2008 | 05:41 PM
  #43
Mayfair's Avatar
Mayfair
Don't forget to trim the pins that you install, otherwise they'll hit the metal pillar as you are trying to re-install it. I found that out the hard way. [:@]
Old Jan 3, 2008 | 06:41 PM
  #44
reed's Avatar
reed
Very nice job, but we need a full throttle picture pegging that boost guage
Old Jan 3, 2008 | 08:42 PM
  #45
chet's Avatar
chet
ok i got it all in and wired up but now the only gauge that works is my vaccum. I made a homemade T and put it in my trans line i took it for a short trip and its about 25 or so outside so it might not have warmed up enough and i spliced into the wires on my oxygen sensor and it doesnt work so if anyone could help with which wire to connect to when i replace my sensor would be alot of help. I've also got an 0132 code and i cant find what it means.
Old Jan 3, 2008 | 08:44 PM
  #46
burban2002's Avatar
burban2002
ORIGINAL: Mayfair
Excellent tip, I'll have to keep that in mind
Old Jan 4, 2008 | 12:39 PM
  #47
Mayfair's Avatar
Mayfair
ORIGINAL: chet
What 3 gauges did you hook up?
Old Jan 4, 2008 | 01:09 PM
  #48
chet's Avatar
chet
Trans Temp(it may work but its only 20 outside with a wind chill of low teens) A/F, Boost/Vaccum. Thanks for the write up as it really made this alot easier than it would have been.
Old Jan 4, 2008 | 04:07 PM
  #49
Mayfair's Avatar
Mayfair
You did a
Trans Temp
Boost
and an A/F ??
What is an A/F ?
Are they working fine now?
Old Jan 6, 2008 | 01:28 AM
  #50
chet's Avatar
chet
A/F is air fuel and yes they are working i just didnt give the A/F enough of a chance to warm up. Once again i would like to thank you on an EXCELLENT write up on this. I never would have cut and completely demsolished my old pillar if it wasnt for this write up. It turned out great thanks to you.
ohh and i prolly more than doubled what i cut out(and drilled out) in the first pictures but i was in the zone and didnt take many pictures of it, plus i couldnt have got as good quality you did.
