Adjusted my valves
Old Jul 9, 2007 | 10:32 PM
jakebrake's Avatar
jakebrake
Default RE: Adjusted my valves
Steve-o your engine is slightly different both under the valve cover and on the outside. Maybe you need to do a writeup on the newer hpcr engines
Old Jul 10, 2007 | 11:34 AM
Drew's Avatar
Drew
a write up for allfour would be good. one for the 12 valves, the 24valve VP44's, 24 valve HPCR's and the 6.7's.
there is a slight change between the 05 and 06 engines with the way the injector harness connects, but past that it is the same.
Old Jul 10, 2007 | 12:10 PM
Mayfair's Avatar
Mayfair
I think they all should be put in the DIY section once done. That would be COOL !!
Old Jul 10, 2007 | 12:26 PM
kg1687's Avatar
kg1687
I think that's a good idea, I'm planning on doing mine maybe next weekend not exactly sure yet. I'd be using the hansen manual which suggests 150k for every valve adjustment. If I remember right that is, it's not onhand right now. I could take pics if ya would like.
Old Jul 10, 2007 | 12:32 PM
Mayfair's Avatar
Mayfair
Yeah dude,click away. You can never have too many pics for a DIY project.
Old Jul 10, 2007 | 12:49 PM
Drew's Avatar
Drew
yea, it's 150K for the HPCR's. I think it was a bit less for the VP44's, and even less for the 12 valves.
Old Jul 10, 2007 | 04:10 PM
zach_deerefan's Avatar
zach_deerefan
yeah a DIY would be awesome because i'm 250 miles away from 60,000. that would sure beat taking it to the stealer. whats the easiest way to turn the engine over while setting the valves?
Old Jul 10, 2007 | 04:55 PM
steve05ram360's Avatar
steve05ram360
you should be good to 150k... but it never hurts to have a look at them...
Old Jul 10, 2007 | 05:06 PM
Drew's Avatar
Drew
ORIGINAL: zach_deerefan
a 7/8'son a breaker bar on the end of the crank.
to do an easy summary, bring #1 to TDC then check #1 - Intakeand Exhaust #2 - Itake #3 - Exhaust #4 - Intake #5 - Exhaust, then rotate crank 360 degrees(one full revolution) then check #2 - Exhaust #3 - Itake #4 - Exhaust #5 - Intake #6 - Intakeand Exhaust
intake gest checked at 0.010" and the exhaust gets checked at 0.020"
Old Jul 10, 2007 | 10:30 PM
Super Dave's Avatar
Super Dave
My crank pulley had several 15mm bolts, IIRC. I put a socket on one and used a long handle 1/2" ratchet and turned it that way. I couldn't see them at all, I had to do it by the braille method[:@] The fan and shroud are so close to the engine there wasn't any other way to turn it over. You just have to turn it real slow due to the compression
Figuring out how to turn the engine over was the hardest part of the whole job.
If no one beats me to it, I will do a DIY on the CR valve adjustment this Sunday.
