Thuren Steering Stabilizer installed...
Old Jul 11, 2007 | 01:18 AM
steve05ram360's Avatar
steve05ram360
Default Thuren Steering Stabilizer installed...
Installed the new steering stabilizer tonight... makes a nice improvement on rough roads... steering feel is improved significantly. I also looked at the axle placement and noticed that the alignment is off... meaning I'll be getting one of his tracbars next.
Old Jul 11, 2007 | 01:42 AM
firemansdodge's Avatar
firemansdodge
Default RE: Thuren Steering Stabilizer installed...
I just installed the trac bar. It is alot tighter around corner/turns. No more play. It will compliment your setup. Thurens S/S is my next and last of my suspension to order. I also will jump up in tire size also. I think w/ my 33" tires on now. I don't have to be to concern w/ the stock S/S at this time.
Old Jul 11, 2007 | 02:06 AM
steve05ram360
I think with 33's you'd be suprised @ the improvement... one of the roads nearby is pretty crappy and I'm able to hit the bumps alot easier with all of the components now installed. when I wsa verifying the install I noticed the steering components suck and there is alot of un-necessary movenent IMO...
I am going to see if I can get a better swaybar end link setup so the front flexes better. if I could find someone who made some quick disconnects I might be convinced to go in that direction.hitting the trails the last couple of weeks showed me where the shortcomings are...
