A/C question
Old Jul 19, 2007 | 07:12 PM
crazykidjj87's Avatar
crazykidjj87
Default A/C question
So my a/c blows ice cold...only through the 2 drivers side vents. i dont have the selectable for driver/passanger. the passangers side blows out but its not so cold and its not as strong comming out. however the heat blows out all vents fine. any ideas?
Old Jul 19, 2007 | 07:21 PM
kg1687's Avatar
kg1687
Default RE: A/C question
Hahahaha I have the same problem! Not sure though. Also another question is does your a/c pump run when you have it set on defroster? sounds like it kicks in. I've been told it has.
Old Jul 19, 2007 | 07:39 PM
Drew's Avatar
Drew
turn your **** from the front vents to the defrost vents. . .if you still have air blowing through your dash vents your blend door is broken. if things are still working like that should check the shutoff door for that particular vent and make sure it is fully open.
Old Jul 19, 2007 | 08:01 PM
mce's Avatar
mce
Mine does the exact same thing. It's reaaly bad when you stop at a red light for a minute or two, then its almost gets warm from the passenger side vents. I brought my truck to the dealership a few days ago for this problem. They evacuated the ac system and recharded it, can't say I notice any difference.I'm at a loss as to what to do next.
Old Jul 19, 2007 | 10:13 PM
trbodiesel's Avatar
trbodiesel
i have the same problem..havent had time to get back to the dealer lately .. i have had the blend door replaced already due to it being broken.. the a/c has been evacuated and recharged . but it still blows only cool air on the passenger side.. the drivers side is somewhat cooler..but i should take it in to be checked ..if someone makes it in before me and finds the problems let me know
Old Jul 20, 2007 | 10:03 AM
crazykidjj87
well it does switch from the defroster to the vents and through the floor. everything switches smoothly. so im at a loss now too???? ive been told my ducting has come apart but i dont see how seeing as how im getting air flow and i dont have air comming out of my glovebox or any other random place. if anyone finds out please share
Old Jul 20, 2007 | 04:03 PM
kg1687's Avatar
kg1687
What i ment with the defroster is like say you dont' have the ac on. and you switch to defrost. I was told it'll run your ac clutch. Sounds like it if your ac is off when you switch it to defrost you hear something like the ac clutch kick in. could be wrong. But not too worried about it. i'm usually the driver and i can point one of the vents towards the passenger side. also my wife gets cold easy so it's kinda a plus.
