PREFERRED PROGRAMMER
Old Jul 25, 2007 | 09:46 PM
mekanik671's Avatar
mekanik671
Default PREFERRED PROGRAMMER
what is the preferred programmer members here run...??
i see a lot of ppl running the Edge, but what about Banks and Bully Dog??
Old Jul 25, 2007 | 09:52 PM
jakebrake's Avatar
jakebrake
Default RE: PREFERRED PROGRAMMER
I think majority here are running either the edge or tst.
Old Jul 25, 2007 | 09:54 PM
mekanik671's Avatar
mekanik671
pros & cons of edge/tst versus everything else...??
Old Jul 25, 2007 | 10:00 PM
jakebrake's Avatar
jakebrake
Every one I know is either running the edge, tst or the smarty so I haven't had any experience whith the others
Old Jul 25, 2007 | 10:05 PM
NCcummins's Avatar
NCcummins
sorry to but in...but what exactly does TST mean and who makes it and what is the smarty system?
Old Jul 25, 2007 | 10:23 PM
jakebrake's Avatar
jakebrake
TST
Smarty
Old Jul 25, 2007 | 10:28 PM
NCcummins's Avatar
NCcummins
can you use them both together???
thanks
Old Jul 25, 2007 | 10:30 PM
jakebrake's Avatar
jakebrake
I'm not sure on the tstwith smarty. I know you can use the smartywith the edge, and the tstwith the edge. I'm debating on if I'm gonna get the tst or the smarty to stack on top of my edge. Leaning towards the smarty right now.
Old Jul 25, 2007 | 10:36 PM
triton's Avatar
triton
you can't use the TST on your truck if you're inquiring about the 07 in your sig. If it was built before 6/06 you're ok. They had problems with it on the 5.9L built after 6/06 and will tell you... it will burn your pistons up !!
The Smarty is what I'd recommend. I haven't used the BD or Edge but read about many that have and are happy. Unless Edge upgraded their box... it doesn't work on the 07 either.
The Smarty has several different softwares you can download and each has 9 differfent levels of tuning in them. It is a downloader and isn't adjustable on the fly... IMO, it's only draw back. This one also claims on there web site " it's not detecable by the dealer " I've tested that claim and they're right. Now, it something catastrophic happened.... they would find anything you did.
NCcummins : If you don't know much about downloaders, pressure boxes or fuel boxes.... you REALLY need to read up on them and learn as much as you can before using them. You an really hurt your engine if you don't
yes you can use them together. That's where you'll really need to watch what you're doing.
Old Jul 25, 2007 | 10:48 PM
NCcummins's Avatar
NCcummins
so is this what is considered "stacking chips"? and i am for sure getting the edge, but dang i didnt know you could stack or add another...i figured that would start to mess with things!
