2000 Dodge blower motor and dash prob
Old Aug 5, 2007 | 06:28 PM
mopar99's Avatar
mopar99
Default 2000 Dodge blower motor and dash prob
I have a 2000 dodge 2500 cummins and the interiorblower motor currently dosent work and i was asking for any suggestions. The other ques is howdo iget the topportion of thedash out because it is cracked pretty bad.
Old Aug 5, 2007 | 08:10 PM
BrianSudokhoi02's Avatar
BrianSudokhoi02
Default RE: 2000 Dodge blower motor and dash prob
Does your blower work at any speed? If it doesn't work at all, I would start with checking the fuse. If it only works on high then I would check your blower motor resistor control (not possitive how your truck is set up, some will work only on high if the resistor goes or not at all).
[align=left] [/align]
Old Aug 5, 2007 | 08:53 PM
CowboyBob's Avatar
CowboyBob
You can't get to it from the top. You will have to take out the entire dash. The blower motor is inside the air mixture box which is bolted "on the inside" side of the firewall.
Old Aug 5, 2007 | 08:57 PM
CutterW's Avatar
CutterW
A work pickup I drove had very low and very high. and we just put a new switch in and worked fine.
Old Aug 5, 2007 | 09:46 PM
mopar99's Avatar
mopar99
I put in a new blower motor and the old was bad for sure didnt work at all and now the motor only blows on high. So im gunna check the resister would you possibly know a basic location and what it may look like.
