Coolant Temp.2
Old Aug 7, 2007 | 11:42 PM
code's Avatar
code
Default Coolant Temp.2
what would you say. In my 01 my temp. Gauge says 140- line- 190 -line- 240. 240 being red what would you say the line between 190 and 240 would be. I'm guessing 215???? thanks for all your time and info.
Old Aug 8, 2007 | 12:03 AM
Cumminnotstrokin's Avatar
Cumminnotstrokin
Default RE: Coolant Temp.2
My 98 ran right around 190-200 ish or a little above when towing. I believe that it was basically the same motor as an 01, could be wrong though if so I am sure that I will be corrected
Old Aug 8, 2007 | 12:34 AM
jakebrake's Avatar
jakebrake
the line should be 215. Mine never gets that hot so I can't check it with an IR temp gun.
