2001 dually
Old Aug 11, 2007 | 04:11 PM
2001cummings's Avatar
2001cummings
Default 2001 dually
Is it possible to convert those drum brakes and install discs?
The question is, will the ABS still work?
Old Aug 11, 2007 | 04:13 PM
2001cummings
Default RE: 2001 dually
I forgot to mention that I'm lalking about the rear brakes. I'm sure everybody understand that
Old Aug 11, 2007 | 04:22 PM
finny's Avatar
finny
i was thinking the same but the rear drum breaks arnt used enought for me to use money on the convertion.
Old Aug 11, 2007 | 04:31 PM
2001cummings
In my case it's when I haul a lot of weight. The stock brakes are weak.
But maybe the exhaust brake would be better.
Old Aug 11, 2007 | 09:36 PM
Mayfair's Avatar
Mayfair
I wouldn't bother with a conversion. I got almost 100K on my stock drum brakes. You'd be better off spending the cash on an exhaust brake.
Old Aug 12, 2007 | 01:13 PM
2001cummings
You are right, I was just curious if it can be done.
Old Aug 12, 2007 | 02:45 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Hey, 2001cummings, you may want to check out this thread https://dodgeforum.com/m_776097/tm.htm
