Ordered My FASS Today
It should be here by friday........ I ordered the 150 W/O the filters got it for 375.00 . I should be getting my comp box within a month........ Im getting alittle exited.
same price as the 95 and they both push 17 psi ..... buy yeah when its paid off i wanna add injectors and larger turbo. maybe propane all after i get a good tranny..
Since your planning on heavily bombing your Ram, you'll be fine with the 150, otherwise I'd order the 95. I believe the 150 isn't rated for anything less than 500 HP. Something like that ...
Why didn't you get the filters as well??
they make a 200 that pushes 50 psi ...... i was like wow what the hell do i need that for . i figured the only reason i would need it is to say i got it ...lol
I forget what the real reason is, but for some reason FASS doesn't reccomend useing the 150 on your truck unless it's heavily bombed. That's why both Jake and i went with the 95
Not tryin to rain on your parade, jus lettin ya know ..
Main problem with the 150 is that the stock pickup tube isn't big enough to flow that much fuel. You could start cavitating that pump, be safe and get a bigger pickup tube and bigger fuel lines.
