glacier fuel syster HELP ASAP PLZ!!!!
just put on the glacier fuel system and not the check engine light is on, and my truck dost hardly put out nd smoke, no throttle response what so ever... any clues to what might be goin on would be really helpfulll i've went through the conections and every thing looks good to me.... i should just have the pos and neg to the new pump, conect to new connector into the one off the old puump nd power wire any thing i may be missing?? thnx
RE: glacier fuel syster HELP ASAP PLZ!!!!
ORIGINAL: kolb7
When you turn on the truck without cranking it, do you hear the pump running and draining back to the tank ?
Did you clean out the palstic shavings in the tank after drilling in the new pick up tube ? It's possible the pre-filter is clogged. Or, if you got anything in the line, it may have clogged the OEM filter .
here you go... http://www.glacierdieselpower.com/de...dept_id=09-001
