truck shuttering
Old Aug 19, 2007 | 11:46 PM
pngmotoman's Avatar
pngmotoman
Default truck shuttering
well today acouple times when i would start my truck and put it into gear it would start shuttering and even when i started driving it would still be there. then after a few minutes it would stop. any idea what it could be?? if it is the tranny going need to get it to the dealer before the warrenty is up
Old Aug 20, 2007 | 01:11 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: truck shuttering
the engine shuttered or the trans when ya started rollin?
Old Aug 20, 2007 | 01:20 PM
pngmotoman's Avatar
pngmotoman
i wasnt sure. but when ever it was in drive was when it was doing it. so thats why i think that it is the tranny not the motor. it even keeps doing it while driving for a little bit.
Old Aug 20, 2007 | 08:43 PM
KenZ's Avatar
KenZ
I experienced the same thing sorta when I had my powerstroke. Every time I took of with a heavy load I would get a shudder in the drive line. Was told it was the tranny, specifically the torque converter giving up. Was told eventually it would do it with no load and then die. Didn't have it long after that to see if it died or not. I would take your truck in and at least get it documented on paper before the warranty runs out. Then if it does go out after the warranty you have proof that it was a existing problem while still under warranty.
Old Aug 20, 2007 | 08:47 PM
Cumminnotstrokin's Avatar
Cumminnotstrokin
My truck shutters when I am pulling my 5th wheel. It only does it when I start moving from a dead stop, I was told that it is normal not sure now
Old Aug 21, 2007 | 05:22 PM
pngmotoman's Avatar
pngmotoman
thanks for the info guys. i'll go ask the dealer
Old Aug 21, 2007 | 09:15 PM
KenZ's Avatar
KenZ
Shuttering when taking off with your 5'er isn't normal. From what was explained to me the shuttering is from overtaxing the torque converter. I installed a product from Banks called trans command. It helped the slushy shifting of the ford tranny and if I was gentle at take off the shudder was minamal. I don't know if they have something simular for dodge trannys or not. Don't know how heavy yours is, mine dresses out around #13,500lbs. Now run a CTD with 6-spd manual and have lots more power and no more shutter!
Old Aug 22, 2007 | 01:54 AM
pngmotoman's Avatar
pngmotoman
the max my truck saw was the other day when i towed my friends truck to town other than that it is three quads
