Edge EZ
Old Aug 24, 2007 | 05:22 PM
Mayfair's Avatar
Mayfair
Default RE: Edge EZ
I just read up a bit on it actually. Apparently the EZ comes set to level 3 from the factory. I wonder if that's the same as level 3 setting on the Comp box?
Old Aug 24, 2007 | 05:23 PM
Mayfair's Avatar
Mayfair
Default RE: Edge EZ
Here's installation instructions that i found ...
http://www.edgeproducts.com/product_...manual-153.pdf
Old Aug 24, 2007 | 07:31 PM
mopar98's Avatar
mopar98
Default RE: Edge EZ
Get the comp .
I'ts a easy install and has more power.
Takes a little more time to install , but if I can do it mayfair .
U can too.
The power is adjusted on the box . It's easy you just toggle thru
to the level you want and your good.
Yes level 3 is noticeable I don't knowabout the bottom 2 levels.
I haven't really used them.
Old Aug 24, 2007 | 07:52 PM
mopar98's Avatar
mopar98
Default RE: Edge EZ
I just lookedat my book and checked the edge siteand
the ez's highest power level will give ya 65 hp .
The comp box level 2 is 65 hp .
If you go to level 3 that's 80hp.
Old Aug 24, 2007 | 11:13 PM
bway4x4's Avatar
bway4x4
Default RE: Edge EZ
Thanks for the instructions Mayfair, im sure they'll come in handy.
Old Aug 26, 2007 | 02:42 AM
bway4x4's Avatar
bway4x4
Default RE: Edge EZ
Finally got my Edge EZ today. 5 min, real simple install. Level 4 is definitely noticeable, blows black smoke when you get on the pedal... So far i'm very happy with it. If i can just figure out what this damn knocking noise is, i'll be alot happier. However i'll post some pics of the installation tomorrow.
Old Aug 27, 2007 | 12:20 PM
Mayfair's Avatar
Mayfair
Default RE: Edge EZ
ORIGINAL: bway4x4
Level 4 ???
I thought they ony had 3 settings? Did you get the EZ or the Comp box?
